Old 09-29-2019, 03:10 PM   #10
Default Re: Secondary air injection system
The air pump is just a blower motor using brushes no different from starters, blower motors and windshield wiper motors. They would eventually wear out; plain bearings, brushes and commutators. The best way to test the motor is direct wiring to the battery unless you're familiar with wiring circuits to use a jumper across the pump relay.
