Old 09-23-2019, 04:51 PM   #10
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Default Re: Right side head lights dim.
Sounds like a high resistance connection somewhere. You won't find that by measuring voltage at the source.
Look at the connectors for corrosion or heat damage. Wires for corrosion or burning. Pull the bulbs and look for corrosion at the contacts.
Check the ground connections for corrosion or being loose.If all else fails try new bulbs.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
