Old 07-09-2016, 01:59 PM   #2
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: HELP!!! Trailing Arm Bracket Bolt Top Access Point Needed
Originally Posted by carvinbassplyr View Post
Trying to remove the trailing arm front bracket bolts and one of the tack welded nuts that the bolt threads into broke free from the car. So, now the bolt just spins freely and won't come the rest of the way out. Has anyone ever had to fix this and do you know of any access points? Obviously now the car isn't exactly driveable even if I put the rest back together as the bracket will be loose. Feeling really screwed...
Not 100% certain my diagram applies - if it does it appears there's room to cut a slot for open-end wrench.
