Old 05-05-2016, 12:21 PM   #7
Stilettobob
Stilettobob is on a distinguished road
2003 ION-3 Sedan
Default Re: ABS Light on but no OBDII Codes found
sorry for taking so long to respond. Just got the car back from the RI emissions test and had them put it on the super duper OBDII code reader. Came up with a C0045 & C0046 indicating a bad left rear speed sensor/wiring harness issue. I'll follow the above advice and hook a VOM across the two sensor pins and expect to see voltage. I'm also thinking of breaking the rear brake wiring harness under the back seat and check from there which might rule out the exposed (and suspect) rear wiring harness to the rear left wheel sensor. What are your thoughts?
Add to Stilettobob's Reputation
Rate the quality of this post and help Stilettobob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Stilettobob is offline   Reply With Quote
