Old 05-26-2014, 07:50 PM   #10
m1super90
m1super90 will become famous soon enough
2003 VUE 3.0L
Default Re: Thermostat Extension pipe / coolant pipe
Put a pipe wrench on it and twist/force it out. It's scrap now that you've broken the tab of anyhow. Or, drill a hole clean through it and insert a big long screwdriver shaft to twist and force it out. Just make sure the T-stat housing is firmly bolted down first so it doesn't get damaged.
Add to m1super90's Reputation
Rate the quality of this post and help m1super90 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
m1super90 is offline   Reply With Quote
