Old 12-12-2013, 06:51 PM   #12
CheapRacer
CheapRacer is on a distinguished road
CheapRacer's Avatar
1996 SC1
1996 SC1
Default Re: Lowering Ideas? Cut springs?
As you can see I also have a big gap between the top of the tire and the fender opening. I'm going to cut the springs on my Sportsman class 1996 SC-1 but since the only turns it ever makes are onto the return road from the end of the 1/4 mile and never goes any more than 5 MPH from the pits to the starting line it's not going to be a problem for me and might even help my ET and MPH by cutting down on the airflow(drag) under the car. It would be a totally different story if the car was still on the street - no way would I do it then. All the advice you've gotten in this thread is for your own good. Cut coils on a street car is just asking for trouble especially if the roads in your area are not in the best shape.
Green 1996 SC-1, Stock, Sportsman class Drag Racer, 17.97 ET @ 75 MPH.
Green 1996 SC-1, 355 Chev, NHRA/IHRA 10.90 class.
1994 Chev ext cab short box 2WD Daily Driver
Add to CheapRacer's Reputation
Rate the quality of this post and help CheapRacer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CheapRacer is offline   Reply With Quote
