Old 12-12-2013, 02:20 PM   #7
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
Default Re: Lowering Ideas? Cut springs?
Originally Posted by Saturnkid36 View Post
Don't get me wrong or anything, thats a great deal, but still not in the budget, i'm trying to fill in the ugly wheel gap that my sc2 has between the tire and wheel well. I'd like to fix that and it be around 2in from the ground, so pretty low, for the slammed look I suppose
Going that low on cut stock Saturn springs would be dumb. You really need a full adjustable coilover set and a lot of camber control to attempt it and even then you'd have a car that can't handle.
I've had my car that low for a few weeks on coilovers and while looking pretty cool the car sucked.
After that the suspension arm changes from down stream to the wheel to upstream to the wheel (as seem from the chassis), our cars start doing stupid things.
The other side of things is to run a bit more tire. it can suck up some of that gap, then take up a bit more with either a small spring cut or a good set of springs.
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline   Reply With Quote
