Thread: suspension
Old 10-01-2013, 06:05 PM   #9
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
Default Re: suspension
To clear up some bar discussion. The rule of thumb is stiffen the end you want to slip, soften the end you want to stick.
Really it is a differential game.
If you want the rear to step out you can dial in more positive camber, run more toe out, uprate the rear springs, go with a stiffer rear bar or increase the rear tire pressures...
Or you can do the exact opposite to the opposite end.
So by running a softer front bar you are basicly doing the same thing as running a bigger rear bar.
But you have to be careful with just jumping into this setup as On a suspension that is too soft you will be generating too little wheel rate, positive camber will dial in, and the whole car will roll too much and the car won't hold a corner; Depending on your tires being able to generate enough force to compress the suspension.
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline   Reply With Quote
