Old 08-02-2013, 03:03 AM   #2
smwalker
smwalker has a spectacular aura aboutsmwalker has a spectacular aura aboutsmwalker has a spectacular aura about
2008 Astra XR
Default Re: buying astra: carfax shows engine wiring repaired/alternator replaced. Why???
Hey brice. Have not heard of wiring problems that are common. With the alternators there was a chirping with the AC on. Soloution was to replace the pulley. But it needed a special tool that none if the gm dealers had so they ended up replacing the whole alternator in some cases.
Could be that, maybe.
Get on yelp.com and find a well reviewed mechanic near the seller and have them take it over there for an inspection. Cost you 100, but could save you thousands.
Good luck!
Add to smwalker's Reputation
Rate the quality of this post and help smwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smwalker is offline   Reply With Quote
