Old 03-14-2013, 02:23 AM   #5
Chazberry
Chazberry's Avatar
1995 SW2
2003 VUE 3.0L
Default Re: P0128, clunking noise on cold start, whistle noise from front right
Originally Posted by sgringwe View Post
I cleared the codes and if the same code comes back I will probably just take it in.
How many miles do you have? Since the Intake Manifold has to come off to do the T'stat, good time to do the Plugs and Cam Cover Gaskets. One caution on the T'stat - it's real easy to break the tab that secures the T'stat Housing Extension Tube.
Add to Chazberry's Reputation
