Old 11-25-2012, 07:29 PM   #5
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: changed thermostat now i got no heat HELP!
Originally Posted by hoffman_BMX89 View Post
Thanks for the input guys I have tried all of this and still no heat. I would get a bit of heat at the beginning and then nothing. The temp gauge is all over the place too I will be at 1/2 then all of a sudden to below 1/4 I have decided to take the thermostat out and replace it again I think it's faulty. Let me know what you guys think.
To best of my knowledge each engine with water pump requires a coolant bypass system to circulate coolant when the thermostat is closed.
The 3.5 engine uses the heater core and throttle body de-icer for the bypass.
I suspect the 2.2 does likewise. So, the question is - could the heater core be clogged?
There are probably coolant hoses leading to throttle body - check these for heated coolant soon after engine start.
No flow to either and the wildly swinging ECT could indicate air blockage downstream of thermostat - bad thermostat - bad water pump, etc.
