Old 01-03-2012, 08:10 AM   #2
Signmaster
Default Re: car wont start. battery?
If the car is turning over and simply not starting it's probably not a battery issue. If you turn the key and nothing happens it's still probably not a battery issue, as just about any battery should turn over an S Series unless you are in the Actic and running 20w-50 oil.
Can you descibe more in depth what happens when you turn the key?
