Old 08-09-2011, 01:52 AM   #52
Default Re: 98SW2 Re-Ring project
Brushes, 3 day delivery. http://www.mcmaster.com/#tube-hand-brushes/=djg1vr Use horse hair and jut clip th loop off the end and chuck up in the variable speed drill. Flood with brake cleaner and brush for effect. Nylon works as long as you remember it will melt. They have others. This place has them but you end up buying a bunch but they are cheap. You want the 1200 manual bristle brushes. https://www.solobrushes.com/producti...&CrossRefID=91
Harbor Freight even sells an assortment. http://www.harborfreight.com/9-piece...set-90631.html
Avoid brass, abrasive loaded nylon, or steel brushes as aluminum abrades rapidly.
