Old 04-06-2016, 12:07 PM   #14
Steve44
Steve44 will become famous soon enoughSteve44 will become famous soon enough
Steve44's Avatar
1999 SL1
Default Re: 97 SC2 (No ABS) Brake Pedal goes to the floor
Although I don't ever recommend pressure bleeders, I'm going to assume that you have indeed bled all air from the system. Based on that assumption, here's what you need to do. Pull up your parking brake lever.
Count the number of "clicks"
If You have more than 5 clicks, your rear shoes are out of adjustment.
Proper adjustment of the rear shoes (assuming you've installed them correctly)
depends of the drum being free of any rusty outer lip.
If there is this lip, take some 40 grit sandpaper (Or whichever method the next 4 people will suggest) to clean the surface.
Now you can adjust the shoes, then put the drum back on.
Adjust until you have a slight drag, not hard to turn.
Hope that helps.
The SL1...The Lucky Car
The SL2..The awesome deal.
The #3 Silver SL2 FIVE SPEED!
World's biggest fan of doing it the easy way.
Add to Steve44's Reputation
Rate the quality of this post and help Steve44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve44 is offline   Reply With Quote
