EGR Code P0405
Hi all,
I am working on a new-to-me 2000 SC2 with a 1.9L DOHC engine. The check engine light is on and my scanner reveals P0405 code.
I have read numerous posts on this site about cleaning the EGR valve and ports and have done so several times only to have the code reset within a moment or so. In one post in particular the pin-out for the valve was listed. The post stated that the valve receives 2 voltage sources: 1) a 5v source for the sensor position and 2) a 12v source for the servo motor that moves the pintle. When I remove the connector from the EGR valve and probe the connector I read 5v on the 5v source. Using a 12v test light from the 5v source to ground causes the light to glow. With the connector attached to the valve the 5v remains. So far so good.
When I probe the connector for 12v I only read 8.5v. A test light hooked from the 12v supply wire to ground fails to light and the 8.5v goes to 0v. Further, if I reconnect the wire to the EGR valve the 8.5v goes to 0v. I checked for a short from the 12v pin on the EGR valve to ground and none exists.
From where is this 12v derived? Has anyone else experienced this issue? Where can I find a wiring diagram to aid in trouble shooting this problem?
Rate the quality of this post and help 2slo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
