Old 09-03-2019, 02:09 PM   #15
PaulR
PaulR will become famous soon enough
Default Re: XE Rear Doors - Wiring
Originally Posted by AstraFasta View Post
That sounds painful. Glad you have the lock working which is the most critical of the systems. I just leave the rear window closed and speaker off.
Did you check all the fuses?
I see in David R's photo below, he has a lot of wire cracking at the rectangular connector. Did you check/replace wires to that point?
There is a fair chance the pick and pull harness had broken wires also that intermittently work and are cracked inside the insulation in several places.
Also check all the male and female pins both visually and with multimeter. It is possible several female pins are overbent so need to be tightened.
Double check your rewiring colors are all correct. An Astra owner made that same mistake last month and swapped two wires for perfect operation.
At the connector end, I would quickly check continuity for all grounds to body. Then check power with multimeter. Wiggle the wires a bit to see if any change readings.
I don't see the window or speaker breaking on these. You could test them insitu for fun. The speaker will show some resistance. I can't remember if the window switch is just on-off or some fancy scheme.
Alternatively, you could remove door panel and check wiring. The door panel comes off easily but a bunch of plastic tabs fell off my front door and I had to epoxy them back together so that took more time than expected. I wouldn't bother doing this as the wiring harness seems to be the typical issue.
Buy the repair kit. I went to the local pick and pull also and found the wiring broken or cracked in the same exact spots on the only two cars in the yard. The wire insulation the factory used was junk and the way that they routed the wiring was just plain stupid.
PaulR
2008 XE5 CEL Special Edition, 5 speed, heated seats, panoramic moonroof
Add to PaulR's Reputation
Rate the quality of this post and help PaulR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
