Old 08-06-2019, 03:12 PM   #7
David R
2009 Astra XE
1997 SW2
Default Re: XE Rear Doors - Wiring
My guess would be that if, it was mostly working before and now nothing is working then you have switched/crossed wires while splicing. The crossed wires are possibly causing an in series circuit behavior for the rear door circuit. For example, maybe the door lock solenoid is in series with the window power and the other door lock, so nothing works.
Or
If you didn't re-splice all the wires, now another wire is broken.
Or
Even though you spliced the wires, now one of them is broken else where. I replaced about 10" of wire, but I still had to use the stubs of wire on the connector. I did the rear passenger last year this time and the lock doesn't work again. Window and speaker still work.
2009 Astra XE 5sp 200K km
1997 SW2 DOHC Auto 330K km - Stored for winter, used in summer
Add to David R's Reputation
Rate the quality of this post and help David R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
