Old 07-21-2019, 09:19 PM   #25
JFS
JFS has a spectacular aura aboutJFS has a spectacular aura aboutJFS has a spectacular aura about
JFS's Avatar
2008 Astra XR
Default Alldata Conundrum
Helo Astra fans,
I am getting ready to do my long delayed strut, spring, and shock installation. I have a couple questions regarding tools. In the following video, the tech reassembles the strut and springs with a 21mm ratchet in an air tool while held in the retention device. He does not use a torx tool to hold the inner portion so that it might be tightened.
https://www.youtube.com/watch?v=FVpRtWN3f4E
(advance to 8:20)
I was hoping for better info with my alldata account. While it addresses the need on both tightening elements, it shows what I believe is an open O2 sensor specialty ratchet. These are almost universally 22mm, NOT 21mm. None of the O2 sensor ratchets that are in my German set seem likely to handle the foot lbs. prescribed in this awkward spot; too loose as well.
Am I missing something? Is this another type of ratchet that I am ignorant of?
Capture from Alldata here:
Please let me know your thoughts.
Add to JFS's Reputation
Rate the quality of this post and help JFS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JFS is offline   Reply With Quote
