Old 11-05-2013, 11:21 PM   #5
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Default Re: Warm 98 SL2 Engine Hesitation when changing throttle position upward
With 170K on the engine and it being a DOHC motor, I would do the compression test, There known for burnt exhaust valves, Most likely if thats the case the reason it runs better above the 2500 rpm range is because ignition is happening at a faster rate before the air/fuel mixture exits the burned valve, If you find compression lower in one of the cylinders you could stop all of your tests because that will be your issue....
CHECK YOUR OIL!
Add to SL19302's Reputation
Rate the quality of this post and help SL19302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
