Old 01-28-2010, 02:58 PM   #1
SaturnTech122
SaturnTech122 is on a distinguished road
1996 SL2
Default 1996 5spd wont go into gear
Been a while guys I got laid off from saturn on dec 11th shortly after that my s car stopped shifting inot gear, 96 sl2 manual. So when the cars off the shifter moves freely through all gears no resistance, when I turn the car on I can't shift it clutch pedal feels softer than usual. When I lay onto the clutch pedal with all I got I can manage to get it into gear. No fluid leaks at clutch pedal is a slight droplet of fluid at bellhousing. Installed new engine and clutch/pressure plate 15k ago due to worn thrust bearing. I don't beat the car so the clutch isn't too concerning? I'm thinking slave failure? Its original w 125,000 miles any ideas would be helpful
SaturnTech122 is offline   Reply With Quote
