Old 09-03-2009, 02:04 AM   #3
mnementh
mnementh will become famous soon enough
mnementh's Avatar
2001 L-Series 2.2L Sedan
2000 SL1
Default Re: 2002 L100 rear brake noise - drum recommendation?
Also inspect where they turned the drum to be sure they cut all the way down to the gullet inside the drum; I had one shop ruined a pair of drums by turning them down "only to the end of the shiny part" - EXACT QUOTE!
Then, the edges of the shoes would drag, lifting the shoes off the backing plate & causing a howling noise which could not be resolved without replacing the drums. They suggested I should "grind the edges of the shoes to clear"; I demanded to talk to the Manager & resolved it my own way...
mnem
Baby needs NEW SHOES... & DRUMS... & Calipers... & wheel cylinders... EEEEP! When will it STOP? When you replace all those worn out parts, doofus...
mnementh is offline   Reply With Quote
