Old 04-06-2016, 06:29 AM   #13
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Default Re: 97 SC2 (No ABS) Brake Pedal goes to the floor
Why are you using DOT4? DOT3 is what is recommended IIRC. That being said have you replaced the other wheel cylinder? I may have missed it but did you replace all brake hoses and calipers? What order are you doing the bleed in? Are you using a small hammer to tap the calipers and cylinders while doing the bleed (yes air can and will "hide"). What condition is the master in? BTW re having to put the wheels on or "torque" the lugs. Not necessary. Just put the rotors on and "snug" the lugs. It's all you need. Did you grind the "ridge" down on the rear drums BTW? If not, do so. Than readjust the rear brakes and see where you are.
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
