Old 07-04-2019, 03:04 AM   #222
454cid
Default Re: and so it begins....
Originally Posted by trottida View Post
I'll answer my own question.
First photo is a cold engine measure, second photo is immediately after shutdown and the last photo is after 5 minutes. Yes, I'm due for an oil change; this has about 7000 km on it.
I've noticed it takes awhile for the oil to get back to the pan on the LLO...Although part of my trouble in getting a good reading is that I have hard time seeing new oil on the dip stick. Before I changed the oil, I probably wasn't letting it sit long enough and I was assuming massive oil consumption because the level on the stick was low, and the blue smoke at idle. Now that I've run it a bit, I don't have the blue smoke.
1999 Chevy K3500
Add to 454cid's Reputation
