Old 10-23-2017, 09:27 PM   #33
uccoskun
uccoskun is on a distinguished road
Default Re: 2002 Saturn SL1 Quill Seal Removal
If you want to do this right then buy the LUK clutch and flywheel for a 91-98 Saturn part number 04-115. This one: https://www.ebay.com/itm/LUK-PREMIUM...cAAOxyOlhS9D~W
Either replace the flywheel or buy a new one. The input shaft splines must be cleaned and lubed and the clutch hub splines cleaned and lubed. After lubing wipe excess off with a paper towel as excess lube will be immediately deposited on the friction disk.
You can also buy a heavier duty clutch.
Trans must remain in neutral or the blocking rings stick.
Shifting is likely a combination of things including the fluid. Dexron-3 is only recommended for emergency use by the OEM. the manual used a proprietary lifetime fluid after the first and only change at 6000 miles.
I finally pulled the trigger and order an LUK set with tie rod ends and another ball joint.
Lets do it right and move on. I might sell my replacement brute on ebay if somebody wants it. I will update it if I can install it over the weekend.
Thank you for your help all.
Add to uccoskun's Reputation
Rate the quality of this post and help uccoskun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
uccoskun is offline   Reply With Quote
