Old 10-21-2017, 05:05 PM   #22
uccoskun
uccoskun is on a distinguished road
Default Re: 2002 Saturn SL1 Quill Seal Removal
Hello:
I did the basic clutch test. I run the car, put it in the first gear with clutch pedal in. I waited 3 minutes without any rolling. I did this test twice without any rolling at all.
I could not do the wire test because of accessibility. I might do it tomorrow.
Here are more observation:
1. The problem shows up randomly, mostly during driving. First time I start the car, it generally shifts fine.
2. I can shift to other gears very smooth, even reverse, but it refuses to go into first.
3. I dont see any improvement if i pump the clutch, it is purely random.
4. I almost think there is something wrong singling out the first gear in the transmission. I opened up the transmission but I did not separate gears or shiftier. Only reverse and 5th gear.
The worst thing, I hope to change pressure plate in a day. Winter is coming.
Am I heading to pressure plate problem?
Thanks you.
Add to uccoskun's Reputation
Rate the quality of this post and help uccoskun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
uccoskun is offline   Reply With Quote
