Old 04-29-2013, 11:44 PM   #3
MyFirstSaturnNJ
MyFirstSaturnNJ is on a distinguished road
Default Re: 99 saturn SL1 idle issue/ Sporadic fluctuating power
Thanks. I tried changing the plugs and wires this past weekend. The old plugs were pretty bad. But there was no noticeable difference. Nonetheless it was probably a good idea to change them anyway. I forgot to use dialetic grease but i did use the anti-seize around the threads. So I guess this weekend I will do the ECTS and thermostat. If we dont get rain again tomm I am going to attempt cleaning out the EGR and maybe reclean the throttle body properly. Is there a certain way to clean out the intake manifold?? There is a ton of carbon built up in there. I am a newbie at auto repair so any help/tips would be highly appreciated.
Add to MyFirstSaturnNJ's Reputation
Rate the quality of this post and help MyFirstSaturnNJ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MyFirstSaturnNJ is offline   Reply With Quote
