Old 08-30-2010, 06:01 PM   #3
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Default Re: 98 Saturn Intermittent Start issue
That is a classic symptom of a bad starter.Sometimes when it is acting up, you can bang on with a small pipe through the intake and get it to work. I believe the temp correlation is merely coincidental. I know you said yours had been replaced recently, but those rebuilt units don't have a very good track record. Also check your battery cables and connections including the ground.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
