Old 08-30-2010, 05:50 PM   #2
Default Re: 98 Saturn Intermittent Start issue
Look for the starter relay interrupt buried in the driver's side dash harness. Its just a common 87A relay used everywhere else. Try using your remote again to Unlock the doors while simultaneously enabling the relay otherwise rap the relay a few times to allow the internal contacts to make again. Pins 30 and 87 are used to complete the starting circuit between the ignition switch and starter. In sequence; ignition switch, starter interrupt (theft deterrent) relay, clutch safety switch and starter solenoid (pink wire). You can always bypass this relay by splicing the above two wires together from their corresponding relay pins.
