Old 03-08-2018, 09:15 PM   #3
Default Re: Got Spark, Fuel and compression. Still no start
Srjs28, fuel, spark and compression but the engine won't fire up?
1-Did you verify fuel is injected into each cylinder? After several failed starting attempts, plugs should wreak of fuel, be wet and smell of fuel to verify injectors are operating.
2-Did you verify spark on each plug? The ICM/coil pack/plugs can be removed, reconnected with plugs laying out in the open and grounded to the engine block while someone cranks the engine for you to observe for spark.
