Thread: 1997 Sw2 Dohc
Old 10-15-2014, 05:51 AM   #7
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Default Re: 1997 Sw2 Dohc
Originally Posted by Tenzinkat View Post
I did pop the valve cover! The top timing chain guide had shredded apart an the timing chain was starting to eat into the valve cover. An yea the two quarts of missing oil I didn't notice because when I first bought the car the oil level was right! Less than three weeks later two quarts were missing! Come to find out some of the metal debris ate the front seal up! So I have my new complete timing set in. I will be doing the timing chain this Thursday!
With the amount of oil its using chances are it was run low at one point causing the wear on the timing set, A piston soak could help with the problem however dont expect a miracle, It really all depends on the condition of the rings PRIOR to the soak.
CHECK YOUR OIL!
Add to SL19302's Reputation
Rate the quality of this post and help SL19302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
