Old 09-21-2010, 08:25 AM   #4
David 93 SL2m
David 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the rough
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Post Re: Changed 4-cylinder engine oil, now have ticking noise
Hmmm. It could be the belt tensioner, or one of the components that get turned by the belt. This evening I'll temporarily remove the serpentine belt, run the engine for less than 1 minute, listen for the noises, replace the serpentine belt, and report back here.
I forgot to mention none of the idiot lights are coming on, which is a good thing.
I briefly searched the SaturnFans ION forums where the Ecotec engines are also used. It seems the Ecotec engines can be a bit noisy; are not uncommon; they get louder with age; and sometimes the noises are due to lifters, injectors, faulty oil filters, for 5-speed manual transmissions a heat shield under the exhaust manifold, and maybe oil issues.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Add to David 93 SL2m's Reputation
Rate the quality of this post and help David 93 SL2m reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
David 93 SL2m is offline   Reply With Quote
