Old 07-13-2009, 02:44 PM   #2
madpogue
1996 SW2
Default Re: Cahnging oil pan, where can I get new pan bolts?
I'd be surprised if they weren't standard M6x1.0 bolts. But since they're steel, going into aluminum, you're more likely to strip the threads on the block than on the bolts. If you're worried about ROUNDING (not stripping) the heads, use a 6-point socket.
