Old 12-14-2013, 03:33 PM   #5
jmelvin8
jmelvin8 has a spectacular aura aboutjmelvin8 has a spectacular aura about
jmelvin8's Avatar
2001 L-Series 3.0L Sedan
Default Re: Speedometer/odometer not working, OBD showing all codes
Is it possible the ECM could be bad, if ruling out the BCM? Could ECM failure cause the OBD to puke out all it's codes? Ha. I am going to rule out the BCM at the moment, so that I can approach it with a different frame of mind.
Add to jmelvin8's Reputation
Rate the quality of this post and help jmelvin8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jmelvin8 is offline   Reply With Quote
