Old 08-09-2016, 12:58 PM   #17
Default Re: subtle "rod knock" like sound, but the pattern is wrong
Do not fill above 1/2 way up on the crosshatch cold.
Get a mechanics stethoscope and start probing around and locate the loudest points.
There is nothing that is supposed to sound like that so finding the exact area is critical to guessing what it is. http://www.harborfreight.com/mechani...ope-69913.html
It might be a rather worn thrust bearing bouncing on the pressure plate fingers, how old is the clutch?
