Old 08-08-2016, 01:28 AM   #13
billr
Default Re: subtle "rod knock" like sound, but the pattern is wrong
Broken springs in the clutch disk hub?
Remember this? "Sound goes away when I step on the clutch or put the car in neutral and coast regardless of engine speed." Did you ignore the BS and check crank end-play as suggested by me?
Add to billr's Reputation
