Old 05-22-2013, 09:31 PM   #10
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: Steering rack and pinion possible problem.
Originally Posted by awakenthedead View Post
finally had a chance today to get under my car and tighten up the rack and pinion and low and behold those bolts are crazy tight to begin with. are there any rubber or plastic bushings that are in the mounting holds that might have disintegrated? otherwise everything looks normal and the bolts at super tight so thats not the problem.
Most Vue's have some front end noise.
What year is your Vue? There's at least one service bulletin to "adjust" the intermediate steering shaft pinch bolt for 2004 Vue.
The file's in post 13 of this thread:
http://www.saturnfans.com/forums/sho...d.php?t=180764
