Old 05-27-2012, 05:13 PM   #2
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: "Underhood Foam Part"...need help identifying (2005 Vue)
Originally Posted by kriswinner View Post
Can someone help me identify this part?
I'm looking for the name and part number for both the right and left sides.
Thanks,
KW
See the thumbnail ... does item 5 look correct ... if yes - both sides are same part number.
Your local GM dealer could obtain but methinks you'd be better off using one of internet suppliers.
I googled 22690380 and GMPartsGiant.com has for 8.18 each ... you can probably find cheaper.
