Old 07-12-2010, 03:56 PM   #3
smailmanstn
smailmanstn is on a distinguished road
Default Re: Air Vent Control Not Working
I had a similar (if not the same) problem with my "08 XE, a little over a year ago. Under warranty, my local Saturn dealer replaced some switch or relay in the control panel.
As I recall, the A/C would only go through the floor vents, and the defrost position pushed through the front dash panel vents, as if the control switch were miswired. But i knew that wasn't the case, because the problem DEVELOPED: the controls worked correctly up to that point.
I had the impression that this was not an unknown problem. The dealership fixed it in a couple of hours (I belive a computer reset was involved). Mine has been working perfectly since. Hope this helps.
Add to smailmanstn's Reputation
Rate the quality of this post and help smailmanstn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smailmanstn is offline   Reply With Quote
