Old 04-03-2017, 08:17 PM   #9
Bildo Baggins
Bildo Baggins is a jewel in the roughBildo Baggins is a jewel in the roughBildo Baggins is a jewel in the rough
Default Re: 98 SC 2 front shifting feeling when braking
I assume when you did CAs that you checked or replaced sway bar bushings as well. It does sound similar to my situation as mentioned by another here. I would get a pull and a shutter on hard brake exiting highway etc.
Mine was the bushing which appeared fine visually but a pry with a bar and pressure off bar showed bushing was pretty much gone inside. Just slapping metal on one side.
I'm sure there are other causes but I'm not familiar with what they may be.
Bill from Extreme Southern North Carolina
'97 Satty SL2
280Kish miles
Add to Bildo Baggins's Reputation
Rate the quality of this post and help Bildo Baggins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bildo Baggins is offline   Reply With Quote
