Old 01-24-2016, 12:31 AM   #23
crobey
crobey is on a distinguished road
Default Re: Clutch Hydraulics Diagnosis
After several months of difficult shifting I found this article. Spot on!! Since it happened over time I didn't notice the clutch engagement spot moving closer to the floor, but that is what happened. It went from 1 inch from the floor to about 2 inches from the top after replacing the master and slave unit.
If you are going to make the change, just go ahead and change out your motor mount while you have everything taken apart.
Also if you have ABS you don't have to unbolt and move it out of the way but it will be very tight.
crobey is offline   Reply With Quote
