Old 03-13-2012, 08:03 PM   #14
off-track
off-track's Avatar
Default Re: HVac Lights not working!
I was guessing based on the size of the glass protruding from the socket.. and I was wrong. A #161 is a shorter bulb. #74 & #73 are what to look for. You can get them in blister packs from any parts store.
FWIW, it's usually a good idea to clean the cup socket with some alcohol or contact cleaner before installing a new bulb. That socket tends to get gummed up from spilled soda's over time.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
