Thread: overheating SL1
Old 02-17-2017, 06:47 AM   #2
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Default Re: overheating SL1
If you constantly get "air in the system" you need to have the cooling system sniff tested. Air pockets around the ECTS can cause the fan to malfunction. That being said I don't think I read what year car it is. If prior to 2001 (IIRC) it has the poorly designed resin tip sensor. The new sensor will be brass tipped. Once you have that in there, see how the engine/fan behaves. If it still does this try turning the AC on which will force the cooling fan to come on. If the engine cools down than it could be the relay. Don't rule out a bad fan motor though
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
