Old 02-16-2016, 11:40 PM   #4
Default Re: Am/fm radio problem
So all of this began to happen with your radio after you were doing work around the ECM? Was there any wiring problem associated ECM's removal and re-installation? While you were removing and reinstalling that part were you doing so with the battery disconnected or connected?
I'm not at all familiar with the S Series radios and why they should behave unusually in this way. The L Series cars have only one radio with any kind of security built into the unit and although I now have one of them, I've not activated the security feature. In my case the upgrade from the CD-AM/FM radio which was originally in the car, to the CD-Cassette Deck-AM/FM radio was basically a "plug and play" operation with no problems whatsoever.
I would suggest copying your original message here and placing it in one of the S Series Forums where you're likely to get more helpful replies.
322,000 miles - Holy canolli!
Add to pierrot's Reputation
pierrot is online now   Reply With Quote
