Old 08-23-2011, 04:15 PM   #13
Default Re: Need Help! Quad Driver (Main Computer Failure) '96 SL2
I put a '94 SC2 PCM in my '93 SL2 after a 5spd swap. Just plug-n-play for that year range at least, 'cause that's all I did before topping out ~12mph higher then with the SL2 pcm on the test drive
