Old 04-16-2014, 09:44 PM   #13
satlite440
2001 SL2
Default Re: Vehicle won't get up to speed. No codes.
i already told you ,or you skipped it.. when the cat bed breaks up the broken parts flow into the muffler and plug it up as well. drop the exhaust off and go for a drive .. bet it works then and the maf code goes away..the maf is seeing air go in but not enough. cuz the exhaust is still restricted..
