Old 04-12-2014, 08:48 PM   #7
Default Re: Vehicle won't get up to speed. No codes.
Some here, in the S-series forums, can disconnect their O2 sensor for a loud drive and determine whether or not a blocked catcon exists - engine power suddenly coming back with an alternate exhaust hole. If you can run the engine with the catcon disconnected (loud exhaust) and drive around the block, you may be able to notice any dramatic improvement or nothing. This can save you from buying a catcon that isn't damaged.
