Old 12-21-2013, 08:45 PM   #3
Default Re: How can I tell if the inner tie rods are bad?
Only test I know of requires you to remove the TRE from the knuckle and raise it up a bit, if it falls under it's own weight it's bad. There ought to be some kind of shaking test as well but I'm not sure.
