Old 12-21-2013, 07:35 PM   #2
ssewall
ssewall is on a distinguished road
Default Re: How can I tell if the inner tie rods are bad?
Disconnect the outer tie rod end from the knuckle, flex the rod up, and let go. Repeat upper left and right. If it drops after letting go the inner end is bad, but success doesn't necessarily mean it's good.
What kind of problem are you experiencing?
Add to ssewall's Reputation
Rate the quality of this post and help ssewall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssewall is offline   Reply With Quote
