Old 11-23-2007, 05:00 AM   #30
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
Default Re: S-Series Automatic Transaxle "Reverse Slam Cure-All"
Originally Posted by OU812 View Post
On the VB i just received from central valve bodies when i look at the back of the VB there is a hole with a metal disk in it, it has a little hole in it,
is this where the manual valve goes or is this in fact the manual valve and all i have to do is connect the selector pin, is there also some sort of spring that i have to remove from the original VB and use it on the new VB somewhere?
I think the selector pin you are referring to is in fact the manual valve. Don't touch that disk, that's the boost valve. It will put a hole in your head if you try to take it apart without knowing there's a huge spring under great pressure in there.
In this picture the manual valve is the "stick" sitting next to the valve body:
And in this one you can see where it slides in inside the valve body:
Add to plastic torpedo's Reputation
Rate the quality of this post and help plastic torpedo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plastic torpedo is offline   Reply With Quote
