Thread: Emissions
Old 01-08-2021, 09:28 AM   #25
maschinenbauer
maschinenbauer will become famous soon enoughmaschinenbauer will become famous soon enough
maschinenbauer's Avatar
2008 Astra XE
Default Re: Emissions
I cleared the code and continued to drive. Code came back after 100 miles or so. Cleaning seemed to help, but I'm sure there's more crud inside where I can't get to.
I came across a write-up on how to disassemble and fully clean a Volvo Bosch purge valve, which looks very similar to ours. The difficult part would be splitting the glued case without breaking it. Then once you're inside, the o-rings could be toast anyway in which case it's best to just order the new one.
https://www.matthewsvolvosite.com/fo...ic.php?t=54172
So I'm just going to buy the ACDelco 55562350 off Rockauto and be done with it. I'll report back after a few hundred miles of driving with it installed.
'08 Astra XE 5-speed
'72 Chevrolet El Camino
'31 Ford Model A pickup
'69 Lotus Europa
maschinenbauer is offline   Reply With Quote
